96 taurus
Old May 3, 2011 | 12:30 PM
robdaddio69's Avatar
Default 96 taurus
my car will start but cuts off after 2sec checked filter its fine,while i had line off i turn the key the pump will come on for a sec shoot gas out then stops......does this mean 4sure my pump is bad????????????
Old May 3, 2011 | 01:06 PM
way2old's Avatar
The fuel pump will only run for a couple of seconds if it does not see any rpm's from the engine. I would look at the IAC valve. Will the car run if you hold your foot on the gas?
Old May 4, 2011 | 10:43 AM
no if i try hitting the gas it actualy will cut off quiker.
Old May 4, 2011 | 06:08 PM
way2old's Avatar
Have the fuel pressure checked. Also check the TPS and MAF sensor. Unplug the MAF and see if it runs.
Lars(wi)
May 29, 2013 07:22 PM
blixx003
Apr 11, 2007 11:05 AM
blixx003
Aug 14, 2005 03:42 AM
