97 ford taurus Vent problems
Just tonight My 97 ford taurus has had vent problems. when i turn off my car air keeps coming out of the vents. It hasnt done this before. It comes out even when it switch is off. It comes out of the particular vents when its on the right switch, aka vents, floor, window.
It comes out at what ever speed the **** is set at so if i turn it to high, it blows out high.
Has anyone else had this problem?
Any suggestions to fix it??
any help would be great!
Recently, I had a problem with the driver's side window in my '97 wagon. The window continued to work after I pulled out the key from the ignition. I found out the problem was the fuse box was wet with condensation. I took a hair dryer to it and the problem stopped.
