97 Taurus transmission surges while stopped
Old Mar 30, 2007 | 10:48 AM
tanklord's Avatar
Default 97 Taurus transmission surges while stopped
I have a 97 Taurus with 123K miles. It has been very well cared for with all fluids and filters changed on a regular basis. Lately, when I pull up to a stop sign, or red light, it feels like it wants to go on. It has a "surging" feeling. I watch the tach and it may show just a slight bobble, 25-50 rpm max. Engine is tight and runs smooth. What should I be looking at in regards to this problem?
Old Mar 30, 2007 | 06:42 PM
goinstrong's Avatar
Default RE: 97 Taurus transmission surges while stopped
Over 100,000 miles a transmission filter change might help.
Old Mar 31, 2007 | 05:53 AM
tanklord's Avatar
That was changed 10K miles back.
Old Apr 1, 2007 | 07:39 PM
goinstrong's Avatar
With regular maintenance - could be converter or computer trouble. If converter is engaging slightly could be trans. overheating (dirty cooler lines, bad converter, etc.) or could be computer trouble, bad speed sensor (reads that you're moving so engages converter to move you) or engine surging and engaging the converter. If the tach is rising at first then drops back down - engine surge (check engine troubles) if tach is dropping first transmission converter is engaging and dropping idle and it lets go andRPM picks back up - trans. trouble.
ledrew85
Feb 17, 2012 03:04 AM
chipsdad56
Jun 21, 2011 09:49 PM
worriedforddriver
Jan 26, 2011 06:52 PM
sweener
Jan 11, 2010 11:24 PM
4Duh
Sep 6, 2007 06:59 AM
