Bench Bleeding Master Cylinder
Old Dec 8, 2013 | 10:56 AM
makuloco2000's Avatar
Default Bench Bleeding Master Cylinder
So I got a Taurus in today with a pretty good leak from the rear piston seal of the master cylinder and since this is pretty common on the Taurus I decided to show the bench bleed procedure you have to do before putting a new master on. Take a look under the master cylinder on the brake booster and you will likely see brake fluid seepage and bubbling paint. The customer chose Dorman for a replacement over OEM and it actually came with the bleeder kit in the box! Just an FYI I am sure it will help someone.
Old Dec 8, 2013 | 11:02 AM
grindman's Avatar
thank you for your post and vid. not everybody knows how to bench bleed a master cylinder. keep in mind that not every master cylinder comes with the kit to bench bleed. so keep that kit handy for the next time you have to do one
Old Dec 11, 2013 | 12:48 PM
Oh yeah I keep them all, you never know when you can use one.
mike93range
Jul 20, 2010 02:56 PM
treetopp87
Sep 14, 2006 07:41 AM
jcwilliamsjr
Dec 5, 2005 05:35 PM
99 Taurus
Jul 20, 2005 11:15 AM
