cooling system Q's
Old Feb 16, 2011 | 06:17 PM
MJSTaurus's Avatar
Default cooling system Q's
Hi everyone,
Just a few basic Q's here
1. I have a 24v V6. 2000. Where the heck is the radiator drain plug?
2. Got a persistent Low coolant lite. No overheating, Overflow tank is actually too high but I did that by blindly filling it.
3. Does this engine have timing belts or chains?
Thanks and I appreciate your attention!
Old Feb 18, 2011 | 10:58 AM
Chalkman's Avatar
Smile
I have worked on the cooling system before and recall the drainplug to either be well hidden or non existant so I just removed the hose I was replacing and tried my best to capture the coolant - kind of messy though. The 24 V Duratec has timing chains which I think is better than a timing belt - - no worry about replacing the chains. You can see the chain when you remove the oil filler cap. These motors will run forever IF you always keep the oil at the full mark and never let them run hot.
rl_turner
Nov 28, 2006 08:23 PM
bigcars
Nov 16, 2006 12:01 PM
pmkls1
Sep 11, 2006 02:18 PM
Steev
Jul 3, 2006 09:11 AM
waldoranger
Apr 3, 2006 08:46 PM
