dome light staying on after door is closed
Old Mar 31, 2006 | 06:17 PM
phisherman's Avatar
Default dome light staying on after door is closed
Where is the mechanism that controls this? Isn't there usually a little actuator that sticks out, and when the door closes, turns the dome light off?
Old Mar 31, 2006 | 09:04 PM
way2old's Avatar
Default RE: dome light staying on after door is closed
If it is a 96 or newer, the switch is located inside the door on the latch mechanism. Spray some quality lubricant inside the door around the latch and open and shut it a few times. Be sure to do all the doors.
Old Aug 9, 2006 | 02:17 AM
pucknut's Avatar
can u tell me what cleared your problem?......i have the same problem with my 02 taurus
Old Aug 9, 2006 | 09:58 AM
way2old's Avatar
Try spraying the inside of latches and see which door is the problem. If the door is closed and light goes out, that is problem door. You may need to open and close door a few times to get the switch working again. The switch is not expensive but a real PITA to replace.
Old Apr 11, 2016 | 12:11 PM
SevenTrumpets's Avatar
Default me too
It started intermittent, now most of time, seems to be driver's side door (2002 Taurus SES) Still less than 100,000 miles and other than a fuel tank pressure switch has been a trouper.
cynfin13
Nov 11, 2011 03:55 AM
oceanblue_2001
Feb 27, 2010 05:16 PM
Zapman
Feb 16, 2009 06:29 PM
BluProbeGT
May 31, 2007 03:37 PM
Mike11C
May 27, 2007 02:14 PM
