Door ajar light
Old Feb 6, 2008 | 09:20 AM
Finallap's Avatar
Default Door ajar light
2001 taurus...Door ajar light stays on..would not bother me that much,but key warning bell goes off when I am sitting in the car,with the ignition off or on acc. Is there anyway to disconnect the bell
Old Feb 6, 2008 | 12:13 PM
Use Common Sense's Avatar
Default RE: Door ajar light
Have you tried spraying all of your door latches with silicone spray and then work the latches? The switches are in the latches and hang-up after time from crud. Give it a try.
Old Feb 6, 2008 | 03:57 PM
Finallap's Avatar
Thanks I just tried that...Didnt work
Old Feb 14, 2008 | 04:23 PM
6Leaker's Avatar
Your door ajar switch might be cooked. I assume that your drivers side is the problem.
The part number for the L/H drivers door and the L/H rear door is XF1Z 10B987 AA, readily available stock.
mike 96 ws6
Sep 25, 2012 08:25 AM
oceanblue_2001
Feb 27, 2010 05:16 PM
Zapman
Feb 16, 2009 06:29 PM
Mike11C
May 27, 2007 02:14 PM
sshupe
Oct 12, 2005 02:12 PM
