fuel pressure regulator
Can anyone tell me where the fuel pressure regulator is on a 2002 Mercury Sable with the 24v DOHC motor? I've tried searching but am getting very mixed results.
1 Attachment(s)
Follow the fuel rail around to where the fuel line enters the fuel rail. You should see a shrader valve. The pressure regulator is bolted to the fuel rail at that point.
Basically, the fuel feed line is connected to the pressure regulator with a "Quick Disconnect" fitting and the shrader valve is right after it. Basically, you're looking for what closely resembles the included pic. |
