How to disassemble sway bar link
Old Oct 27, 2008 | 07:30 PM
peteryjg2008's Avatar
Default How to disassemble sway bar link
There are squeaks from the front-left bottom only when turn left. I accordingly checked the connections close to the front-left wheel, and found that the little rubber boot on the sway bar link was broken. Do you think the broken rubber boot is the cause of the squeaks?
I wanted to disconnect sway bar link from the strut, but failed today because the bolt was rotating simultaneously when I rotated the nut on the bolt of the sway bar link. Could you give me some suggestions about how to loose the nut on the bolt of sway bar link?
Thanks a lot!
Old Oct 28, 2008 | 06:02 AM
Use Common Sense's Avatar
Default RE: How to disassemble sway bar link
Should be able to place an 8 mm box wrench on the end of the stud to keep it from rotating. I believe the nut is an 18 mm nut. The sway bar end links normally wear out. Their primary sympton is clunking noises even when going over subtle bumps.
Old Oct 31, 2008 | 08:59 PM
Sterling_Six's Avatar
ORIGINAL: Use Common Sense
I thought it was a 15mm...but what year is this Taurus??[:-]
mdenhart
Jan 19, 2014 04:43 PM
MatlockPaul
May 5, 2013 05:35 PM
richsicinski
Jan 8, 2012 12:26 PM
davej
Oct 19, 2006 01:04 AM
91EXPLORER
Jul 24, 2006 11:35 PM
