messed things up
Old Sep 24, 2024 | 11:46 AM
greenthing's Avatar
Default messed things up
I was replacing inner tie rods and the removal tool i rented wouldnt quite fit unless i cut just a half inch from the frame and I accidentally cut a hole in the fuel line and return line in the right front wheel well. Very stupid but it was very late at night and i am old and was tired in a hurry lol. Any way i patched the with rubber hose but had driven it to autozone while leaving a trail of fuel ! then after i had patched it i drove someone to work 25 miles each way and it was blowing fuel out the mufflers lucky i didnt blow up or catch fire. So back to autozone and the code said to replace the coil and spark plugs which entailed replacing the upper manifold gasket which i broke a bolt off of when trying to torque it down. Now it blows alot of smoke not so much a gasoline smell but WTF did I do to my car? 80,000 miles 1999 ford taurus. would a leaky manifold gasket cause this? I replaced the spark plug wires and coil and upper manifold gasket . ANY help would be appreciated
Old Sep 24, 2024 | 04:14 PM
Glad you are here to talk about it
. Fuel lines from the tank can be under 35-60lbs pressure.
Could what you thought was coming out of the muffler be what was being thrown out thru the high pressure leak ?
By the way,,,,,,,,,, what was the code you spoke of ?
Dodg3m4n
Aug 14, 2020 06:51 PM
Sporty7579
May 4, 2016 07:55 AM
adben22
Oct 25, 2015 09:42 AM
popsford
Mar 16, 2013 09:38 PM
fitter1974
Nov 19, 2007 10:52 AM
