No Heat! Coolant flush procedure
Old Oct 28, 2013 | 06:31 PM
makuloco2000's Avatar
Default No Heat! Coolant flush procedure
Had my first one of the season with the usual not enough heat from the vents. While the heater core replacement is recommended too. Depending upon the severity, this coolant flush procedure may also do the trick. Either way it's the first step to replacing the heater core so might as well try it and see. I decided to make a video of the the procedure we use at my shop that is tried and true. Hope this helps!
Old Dec 15, 2013 | 11:55 AM
Hope this has helped some!
Use Common Sense
Jun 25, 2016 01:30 PM
Eligee1
Jan 19, 2012 11:09 PM
BUSTYSIN
Dec 15, 2006 09:01 PM
butters417
Mar 22, 2005 02:21 PM
butters417
Mar 20, 2005 10:38 PM
