Oil lamp keeps flickering
Old Oct 5, 2006 | 02:56 AM
starguard's Avatar
Default Oil lamp keeps flickering
Hi everyone
I have a 96 Ford Taurus GS that I just spent over $400 on emission repair. This car has over 158,000 miles on it, but still runs strong. The main problem I have with it right now is that the oil lamp indicator keeps flickering. I've checked the oil level and it's completely full. I've checked the water level in the engine as well and thats full too. Is this flickering lamp a sign that either the switch or pump are about to go bad?
What should I look for while troubleshooting? Any ideas?
Old Oct 5, 2006 | 03:39 AM
94 4x4 ranger's Avatar
Default RE: Oil lamp keeps flickering
[sm=welcomesign.gif]Sounds like the wire may be shorting or the switch is going bad.[hr]I would wiggle the wire on the side of the oil pan and see if the light flickers.[hr] (with the engine running).
Old Oct 6, 2006 | 02:36 AM
starguard's Avatar
Ill take a look..Thanks
Old Oct 16, 2006 | 11:20 PM
SuperHighOutput's Avatar
Does the engine hunt(try to idle, but ranges from 500-1100)? My sho did that
Old Oct 17, 2006 | 03:13 AM
starguard's Avatar
No, but it did skip at high speeds. After a complete tune up and Class A inspection, it was discovered that the wiring at the switch was damaged. All is O.K. now!
Thanks
Old Nov 30, 2006 | 03:00 PM
zigm28's Avatar
My 2000 Taurus oil light flickers very faintly when I am at a stoplight. The engine idle is steady and when I give it gas, it goes off. It does not do it all the time though. I checked the oil level and it is fine and just had the oil changed two weeks ago. Could this also be bad wiring.
Pathfindr
Dec 30, 2014 01:27 PM
mdbuffy
Feb 27, 2010 02:44 PM
Mach11971Mustang
Mar 23, 2007 01:57 PM
smileyracing
Feb 20, 2007 12:47 AM
dale55
Jan 23, 2007 01:02 AM
