Rear Strut Replacement Procedure
Old May 11, 2014 | 11:17 PM
makuloco2000's Avatar
Default Rear Strut Replacement Procedure
These are quite common the fail by leaky struts but even more so cracked off coil springs which if broken off like this one and the spring settled it digs into the tire sidewall and causes a high speed blow out, very dangerous we have seen it before. Even if you don't plan on doing this job yourself it is a good idea to inspect yours for breakage as shown in the video. Following my procedure makes the job quite simple even on a rusted car if you follow the tricks I have learned over the years.
makuloco2000
Dec 13, 2014 08:41 AM
makuloco2000
May 13, 2014 07:05 AM
makuloco2000
Apr 3, 2014 08:55 PM
HocusFocus
Dec 25, 2012 10:48 AM
toaster
Jul 17, 2005 03:08 PM
