Starting Problem
Old Oct 27, 2010 | 09:16 PM
hoops7's Avatar
Default Starting Problem
Hello,
I have a 1997 Ford Taurus and the car wouldn't start the other day.
I then tried to jump it and it wouldn't work. I took it to a repair shop and
they said that the starter & battery are no good. I then had them replace
those two items.
A few days ago, my car wouldn't start again. I took the key out and tried it
again and again. Finally after like 10 times it started. I could hear
the starter spinning and the battery seems fine. I then looked around
on the internet and someone said that it could be the battery cable
has a short or possibly the ignition coil is bad. This exact same thing
happens every 2-4 days and I'm concerned that one day it will not
start.
What do you think that it is?
Ignition coil, battery cable or something else?
Old Nov 10, 2010 | 10:58 PM
labc26's Avatar
was the starter just spinning not turning the engine over if that is the case the start is not making contact with the flywheel an that would be a bad starter but if the engine is spinning it could be a crank sensor going out that tells it when to fire that would be my first thing to replace but i have seen the coil pack bad too
FL3471
Mar 9, 2013 02:45 AM
Roanbadger
Dec 20, 2005 03:40 PM
moto318
Dec 2, 2005 04:17 AM
MooTony1994
Jul 26, 2005 03:03 PM
DavidR
Nov 29, 2004 03:19 PM
