Steering is too hard...on a 2000 SEL
Does it have excessive/high effort at all speeds? (not just low RPM) and in both steering directions 'equally'.. Vibration/chatter?
Fluid is full,, no leaks,, 'most' times the pump is the cause for high effort.. Any current 'abnormal' pump whirring noise/whine, or has the pump been run dry (system leaks) at any time/s prior to the high effort condition? Could be the power rack too with an internal leak, and a pump flow/pressure test would verify a good/bad pump prior to suspecting the rack.. Without testing its just a guess..
But the vintage and mileage you indicate, I'd first suspect a pump failure for high effort.. Pump failures are ‘generally’ more common than rack issues..
Nichole Johnson
Nov 26, 2014 05:29 PM
Ctwngrl07
Jun 19, 2012 06:16 PM
jeffandteneka
Feb 16, 2007 09:58 AM
