Water Pump Problems!!! Please help!!! 96 TAURUS GL
Old Mar 25, 2007 | 03:26 PM
loverboy0024's Avatar
Default Water Pump Problems!!! Please help!!! 96 TAURUS GL
I have a 96 taurus GL. Gargling sounds were coming from the water pump area, when im idle! I took it to the shop and they said it was my waterpump. I got anew water pump put in. The noise stopped for a couple of days, but nowits BACK!! The same noise is coming from the new water pump! PLease help someone!
Old Mar 26, 2007 | 01:29 PM
goinstrong's Avatar
Default RE: Water Pump Problems!!! Please help!!! 96 TAURUS GL
Could be a crack in a head gasket or in the block or head. If no leaks it could beburning antifreezeand pushing it outthe exhaust. This is usually noticed as white smoke coming out the tailpipe after it is warmed up. The gurgling noise is the absence of antifreeze at the pump. If you're not losing antifreeze I'd be suprised. If it's not smoking at the tailpipe it could still be the same problem only instead the piston is forcing air into the crack (and thereby into the water pump). You may also look for a bolt that someone left out when assembling the pump.
gp2426
Jan 16, 2015 09:06 AM
bearhead
Dec 19, 2009 02:18 PM
hern615
Oct 3, 2008 10:13 PM
99RangerXLT
Sep 15, 2007 10:36 PM
AlphaMan
Nov 28, 2005 12:04 PM
