93-97 probe
What kind of probe?
GT or SE/Base?
The 2.5V6 get's about 165 stock at the crank, I'de use that and assume around 140hp non-modified at the wheels.
The SE/base probe with the 2.0 I4 gets near 115 at the crank and you should be able to get 90-100 at the weels.
It also depends on auto/5sp. If you have the option, get the 5sp, the auto is garbage.
There are TONS of mods you can get for the probe to increase HP. CAIs, cat back exhausts, test pipes, headers, j-spec cams, custom ground cams. Or if you wanto to go ***** Out and buy the KLZE J-spec 2.5 you can get 195-200hp at the crank so around 170 at the wheels.
GT or SE/Base?
