brake problem
Jack up each wheel one at a time in rear and step on brake then immidiately try to spin wheel. If it has major resistance then you should be able to isolate the wheel in question. Oh yeah is it rear disc? If so I would say one of the calipers is frozen. If not you need to look into brake hose restriction also.
sounds like brake hose restriction then. Need to press back pistons in calipers. See if they press harder from side to side. If they do not want to press then crack caliper bleeder and press, it it goes back then you know which hose is bad.
moonunitpurple
Mar 8, 2007 09:51 AM
