Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
Odd noise
Old May 9, 2012 | 11:41 AM
TLGunman's Avatar
Default Odd noise
Issue: noise while driving.
Starting around 30km/h there is a hum from the driver side eng area. Hum is a bit louder when cold, and gets a bit quieter after warming up. At least it seems that way. Maybe I just get used to the sound.
This hum disipates after 55/60km/h, and turns into a constant gurgling/card-in-the-spokes, kind of sound. The volume is steady. Of course it gets faster as I go faster but, it does not get louder as I go faster. Volume is roughly the same at 70, as it is at 100km/h.
When I turn left the noise all but goes away. This is turning left at speed...40km/h+. The sound does not get louder when I turn right but, does not go away.
I have been under the car, and am able to slightly jiggle the inner tie rod. This might be causing some vibration noise but the symptoms dont really match an inner tie rod from what Ive read.
Any help would be great. Thanks in advance.
Old May 9, 2012 | 03:40 PM
bluewind's Avatar
I guess the wheel bearing is shot. Or the tire has an issue. Rotate the tires and see what happens. If everything stays the same its more likely the wheel bearing.
eilatan
Nov 25, 2013 09:01 PM
carl57harley
Dec 12, 2006 01:00 PM
96F350Panel
Oct 27, 2006 10:46 PM
Cougar_Vibe
Mar 12, 2006 08:29 AM
shadowwalker
Feb 1, 2006 09:55 AM
