Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
Straight water in cooling system
Old Mar 5, 2014 | 04:22 PM
fullshaft's Avatar
Default Straight water in cooling system
Hey guys, so here's the deal. Im racing a 94 ford probe at my local racetrack this year. They require 100% water in the cooling system. Does anybody know what I should use? Distilled or Tap, which additives to use to help flow, any rust inhibitors etc? I just need some info. Pretty sure I have aluminum parts in my system. So im a bit skeptical. Any info would be great.
Old Mar 6, 2014 | 06:25 AM
Use Common Sense's Avatar
Distilled is the best to use unless your tap water has a low hardness and low chlorine content will also work. I personally use AMSOIL's "DOMINATOR COOLANT BOOST", to help reduce the surface tension for better BLOCK to WATER heat transfer. I would also drop in a 180° thermostat.
Dosage for AMSOIL's "DOMINATOR COOLANT BOOST": For straight water applications, add 2 fl. oz. of Coolant Boost per quart of water. Use only water verified to contain less than 25 ppm of chloride
Old Mar 7, 2014 | 06:50 AM
tempforce's Avatar
i use water wetter in all of my vehicles. found at jegs, summit, and local parts stores. it's a pink or green color..
Old Mar 7, 2014 | 09:33 PM
fullshaft's Avatar
So I did a little research, seems we have pretty good water around here, so I'll just run tap. I bought some water wetter and some dominator coolant boost. I'm good friends with a racing family, they said to drill out the center of my t stat. Is there any rust inhibitors I should buy? I plan on flushing it out every few weeks so I would think not, but I've been wrong before. Thanks again guys
Old Mar 10, 2014 | 04:26 AM
I don't know about water wetter or others, but the AMSOIL Dominator contains a good dose of corrosion inhibitors.
rl_turner
Nov 28, 2006 08:23 PM
bigcars
Nov 16, 2006 12:01 PM
pmkls1
Sep 11, 2006 02:18 PM
Steev
Jul 3, 2006 09:11 AM
waldoranger
Apr 3, 2006 08:46 PM
