88 Ford Thunderbird Brake valve Problem
Old Mar 25, 2008 | 06:34 AM
rascal's Avatar
Default 88 Ford Thunderbird Brake valve Problem
I have a 88 Thunderbird and the proportional valve of the brake system has failed. I nor my mechanic can find a replacement.Any ideas? Can is be bypassed?
Old Mar 27, 2008 | 12:20 AM
goinstrong's Avatar
Default RE: 88 Ford Thunderbird Brake valve Problem
Your proportioning valve may be hard to find except in a salvage yard (unless you haven't tried the dealer). They sell aftermarket ones (if you cannot get the stock onesany more) that you can hook in and let you manually adjust your brake bias to your liking (which I think is better than stock deals anyway).
Old Mar 27, 2008 | 12:22 AM
goinstrong's Avatar
Bypassing would result in improper braking pressures and likely failure at the rear brakes from too high pressure.
Old Mar 27, 2008 | 06:31 AM
rascal's Avatar
Thanks for the input. I have been seaching for a replacment without any success. The mechanic working on it has obtained a couple of salvage parts but they were in worse shape than the origianl and trying to rebuild the unit hasn't worked out. Can you give me a source for the aftermarket unit. I have been to many internet suppliers and local auto parts stores and they don't list a proportional valve for any car.
Thanks
jenmes70
Jul 29, 2013 07:17 PM
howelldw
Aug 30, 2010 09:51 PM
scrapiron48
South
Apr 5, 2010 10:26 PM
lilfarmergal
May 9, 2008 09:04 AM
lilfarmergal
May 9, 2008 09:01 AM
