91 Thundedrbird Instrument Panel Problems
Old May 6, 2007 | 09:37 PM
JdoubleU21's Avatar
Default 91 Thundedrbird Instrument Panel Problems
I just got a 91 Thunderbird with the 5.0 engine in it, and that instrument panel is dim and barely see able. I have tried messing withe swicth to turn up the lighting and not working. Was wondering if someone has a wring diagram for the instrument panel or even if this has happened to anybody else and if they were able to fix it that info would be much appreciated. Thanks for the help
Old May 7, 2007 | 06:39 AM
decipha's Avatar
Default RE: 91 Thundedrbird Instrument Panel Problems
most probably the dimmer switch they go bad with time, to be sure remove the dash panel around the switch and and jump off the contacts, should light them suckers up some bright
Old May 12, 2007 | 09:30 PM
rustbucket89's Avatar
i have a dimmer switch if you need one..i also have an instrument cluster if you want
mlb
Jan 4, 2008 11:29 AM
razorbacker
Nov 30, 2006 12:17 AM
triley301
Sep 3, 2006 07:47 PM
major99
Jan 28, 2006 09:27 PM
sparhawk12345
Apr 9, 2005 05:22 PM
