91 thunderbird fuel pump not turning off
Old Nov 26, 2007 | 12:30 PM
mtunslip's Avatar
Default 91 thunderbird fuel pump not turning off
I have a 91 Thunderbird and the fuel pump will not turn off. I looked for a relay to see if that was stuck on but could not find one. If you know where it is please let me know. Thank you.
Mike
Old Nov 26, 2007 | 12:55 PM
mtunslip's Avatar
Default RE: 91 thunderbird fuel pump not turning off
Found it. It was in the trunk.
Old Nov 26, 2007 | 01:29 PM
Thanks for the update...
Old Nov 27, 2007 | 11:05 PM
goinstrong's Avatar
Could also have beenthe distributor mounted ignition module. The switch in the trunk usually doesn't affect continual pumping of fuel - it's an auto accident fuel cut-off switch (therefore it has the opposite purpose only , really). That switch should always be on (in other words) unless you crash or jolt your car badly.
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
completemessox
Apr 30, 2008 04:22 PM
completemessox
Apr 30, 2008 12:13 PM
