92 T-Bird
Old Dec 7, 2007 | 07:17 AM
RemRod's Avatar
Default 92 T-Bird
On my wifes 92 T-Bird the Tripmeter and theOdometer just stopped working. The speedometer works fine and they are all on the same middle gauge pod.
Is the gauge pod bad even though theSpeedometer still works or is there another sensor that is bad some where?
-Rem
Old Dec 7, 2007 | 12:21 PM
goinstrong's Avatar
Default RE: 92 T-Bird
The guage likely has a broken gear tooth on the odometer. The trip meter works off the odometer and so if the odometer is broken so usually is the trip meter (so that's no surprise). Most cars are the same way basically. It may be a common problem so look out for identical damage on any replacement part from a salvage yard (lots of recent plastics do not hold up and disintegrate after so many years - oh yeah - did I mention the gears I mentioned are usually plastic?)
Old Aug 15, 2013 | 09:05 PM
mike1026's Avatar
Default Looking for an anwser.
Four out of five times it will start but the one time when it don't start it seems like it is not picking up fuel? It has a new fuel pump and filter's. Does anyone know why this may be happening?
Old Oct 11, 2013 | 07:18 AM
mrwhizard's Avatar
Default 92 T-Bird Odometer
This can be repaired visit Instrument Cluster Repair, Speedometer Repair, Odometer Repair for more info.
Valetineama
Apr 27, 2015 11:43 AM
maiden_fan
Jul 25, 2014 06:02 PM
chris
Mar 27, 2007 10:58 PM
dave00beer
Dec 1, 2006 03:19 PM
Powdered Water
Nov 18, 2005 12:44 PM
