engine swap
Old Sep 30, 2007 | 11:41 AM
91sleepr's Avatar
Default engine swap
I recently purchased a 1991 base model bird with the unworthy 3.8 turd of an engine hey the car has 76000 miles on it and i only paid a hundred dollars for it. How much work does it take to put a 5.0 in it
Old Oct 6, 2007 | 05:15 PM
goinstrong's Avatar
Default RE: engine swap
3.8's were only turds for one reason. They needed steel sleeves in the oil pump housing so as not to wear out the oil pump early. It'sa lot more work, to put in another engine (likely need to swap 302 oil pan) and wiring and possibly transmission, than it would be to have a good machine shop slip in some sleeves for the oil pump on the 3.8. Plus the sleeves might be cheaper. Of course, the 302 is a better balanced engine in general, and the parts are easier to get. Sounds like a great deal on the car at any rate.
Old Oct 11, 2007 | 09:23 PM
tbirdtess's Avatar
Hello
First You will need a 302Ho with it wiring harness. 91 to 93 Thunderbird 302Ho Engine mounts.
Including the Exaust Manifolds.
Yes, the double hump oil pan.
Yes, the 302 will bolt up to your AOD from the 3.8. You can have it rebuilt for the V-8, front clutch mostly.
I have a 351W, AOD & 3.90 rear gear in my 90 T-bird.
I race it on a 1/2 mile asphalt oval.
Paul
bmwrocks03
Apr 21, 2008 09:29 PM
matt95ssei
Apr 5, 2008 02:15 PM
F 150 Bama
Aug 20, 2005 02:06 AM
92FlareSide
Jul 1, 2005 02:30 PM
fordmann67
May 8, 2005 09:22 PM
