-   Ford Thunderbird (https://www.fordforum.com/forum/ford-thunderbird-34/)
-   -   Gear Shift (https://www.fordforum.com/forum/ford-thunderbird-34/gear-shift-23547/)
stubbie Feb 10, 2011 10:40 PM
Gear Shift
I have a 1964 Ford Thunderbird. When starting I have to push the gear shift as high as it will go to get it to start. I have adjusted the transmission end but it has made no difference. Would anyone have had this problem and know how to fix it?
Thank you
hanky Feb 11, 2011 01:08 AM
If I'm not mistaken the neutral safety switch was located on the steering column if the shift selector is also on the steering column.
stubbie Feb 11, 2011 01:13 AM
Yes the Neutral Safety Switch is on the column. I had thought it might be that and was going to look there next.
