How do I remove 1992 door panel?
Do I have to remove the plastic triangle piece around the door handle, or is it part of the whole panel? I just don't want to break any of these plastic pieces.
I know there is the plastic triangle piece above the panel and at lease 1 screw in the lower-rear of the door panel..
Thanks,
Newb
Thanks,
Newb
Welcome to the site..
Removal...
Remove window regulator switch housing. (should screw to the panel)
Remove door inside handle cup (snaps out).
Remove self-tapping screw retaining door trim panel upper front extension assembly. Remove extension assembly.
Remove two self-tapping screws retaining door trim panel to door inner panel.
Lift door trim panel upward and snap out trim panel.
Disconnect wire harness for courtesy lamp.
Removal...
Thank you, that was awesome. The reason for taking off the door panel is the passenger window doesn't go up or down. The motor is trying and the window will go and down with assistance. It is as if the is a clutch (which I know there isn't) that is loose.
makuloco2000
Dec 13, 2014 08:41 AM
henryts77
Dec 4, 2013 08:07 PM
lecocorico
Sep 18, 2009 04:42 AM
