thunderbird smells like gas
Old Apr 26, 2007 | 01:35 AM
rustbucket89's Avatar
Default thunderbird smells like gas
just the other day i was drivin and i got a whiff of gas..it smells like its coming from the back somewhere so im thinkin something along the lines of the tank or someother line is leaking..i quit driving it because i dont want anything bad to happen..has anyone else had a problem like this? also i just noticed there was a recall to fix the fuel lines because they would wear out by rubbing on the floor pan...it said the dealer will fix the problem by putting a piece of plastic around the line...would they do this for free or would i have to pay for it?
Old May 3, 2007 | 10:22 AM
decipha's Avatar
Default RE: thunderbird smells like gas
hey rust... best thing to do when you suspect a fuel leak is to shut that mother off... it would help to post the year... if its less more than 3 yrs old and if your not the original owner im pretty sure they wouldn't do any free recalls... have you checked your gas cap?? make sure its tightened all the way and clicks... next step is to crawl under and look for any fuel leaks... find your fuel pump relay and jump it off so fuel is being pumped with the engine off... check for any fuel leaks
Old Jun 24, 2007 | 01:32 PM
Turbo_Dan's Avatar
what year?
is it modded?
is it a turbo coupe?
is it stock?
and your fine my dad has an '88 turbo coupe it leaks in that same spot where you smell gas but we run it every weekend
prob. theseal for the vent leaks check it and replace it
jeff308
May 25, 2010 05:29 PM
ed88elctric
Feb 28, 2008 11:18 AM
salazarj88
Oct 10, 2007 03:26 PM
salazarj88
Oct 9, 2007 10:55 AM
