03' 4x4 Ranger Clutch trouble
I have a 03' 4.0 stick Ranger. The truck creeps & shift's hard. Replaced the
complete clutch, master & slave twice. Still no answer's... Any idea's? |
From what you describe it sounds like the clutch is not releasing completely.
After replacing the clutch pressure plate and clutch disc , are you sure the disc is not installed backwards ? The torsion springs on the disc go to the inside of the pressure plate. Did you bleed the clutch master and slave cylinders of any trapped air ? Does the clutch pedal at rest have the right amount of free ply ? |
