1999 ford contour help
Old Mar 2, 2011 | 09:32 PM
cdog0809's Avatar
Default 1999 ford contour help
my 99 ford contour has a problem when i slightly touch the gas pedal the car acts like it wants to stall and sometimes it actually dies i have changed the plugs/wires,oil ,trans fluid and it still does it please help asap mileage is 144.588
Old Mar 3, 2011 | 12:27 PM
You might want to check the (TPS) , throttle position sensor.
Old May 17, 2011 | 10:45 PM
cdog0809's Avatar
i have changed that just last week and the problem still exists any other suggestions i've taken it to a mechanic they charged me $150 and told me that they couldn't figure it out
Old May 18, 2011 | 05:46 PM
way2old's Avatar
Could you please tell us all you have done to try to resolve the problem? That way we do not have to guess as to what had been replaced or checked. Thanks
Old May 19, 2011 | 09:31 PM
greasemark's Avatar
I've done so much warranty work on Contours, I wish I could forget it all! These cars (both engines) had many, many problems w/the MAF sensor. Pull codes, and see what the heck is going on. I could imagine anything from TPS to fuel pump/filter problems. Need a little more info.
Old May 20, 2011 | 08:43 AM
cdog0809's Avatar
Default things i've all ready changed
i have replaced the following
fuel filter
tps
plugs/wires
i had a injector cleaning
changed the oil & trans oil
thanx for ur help
jsmith41010
May 23, 2012 03:50 PM
Mary Washington
Aug 26, 2011 01:30 PM
orechia
Dec 30, 2010 06:04 PM
kdbailey
Sep 29, 2008 08:20 PM
95se_mexican
Dec 16, 2006 06:52 PM
