2002 Ford F-250 SD Crew 4WD diesel
Old May 30, 2011 | 02:59 PM
frhrwa's Avatar
Default 2002 Ford F-250 SD Crew 4WD diesel
lately, I've started the motor, tried to roll up the windows, nothing.. radio doesn't work either.. drive down the road and the radio finally comes on, and now my windows work? anyone having this problem or what the heck do I look for to fix this? also, my backup alarm light/button stays lit, press it a couple times and it goes out, but comes back intermittently or when you restart the motor..? of course the backup alarm doesn't work when its lit.. so its useless? and.... if not another annoying item, my overdrive light on the shift lever comes on by itself, you move the shift a little and it goes out, but comes back shortly..? doesn't shift in to overdrive, just the lamp comes on..?
Old Jan 18, 2013 | 07:03 PM
Sounds like a problem with the Accesory Delay Relay for the windows/radio.
On the shifter, the OD button harness runs out the bottom of the shift lever, sometimes the wire will wear through from movement and short against the column metal or bracket that clips the shifter boot in place..
If your game for some in pin point tests, should be able to sort some of the issue out...
Trader4Less
Apr 28, 2016 10:22 PM
john311
Jun 7, 2011 11:50 PM
hilliad
Jul 4, 2010 02:26 PM
dodger
Sep 24, 2009 11:19 AM
rutwad
Mar 29, 2009 08:05 AM
