2005 front passenger window
I installed new front passenger side window switch and also tested the window motor itself and it works. But it still wont work by using either the drivers side or passenger switches. Any ideas would be appreciated.
Thank you. |
Two things you should do first and they are; make sure you have power at the driver's window switch then also make sure you have a good ground at the plug that goes on the switch .The window system is usually fed power through a circuit breaker.
Thanks. It does have power from master switch to passenger switch. I see the switch light go out when I try lowering window from the drivers side.
There usually is no light visable at the switch unless the dash lights are on also.
Are we talking about the same light? |
Yes I did have the lights on. Yes same lights.
