2005 front passenger window
Old Apr 19, 2015 | 08:19 AM
Anybody's Avatar
Talking 2005 front passenger window
I installed new front passenger side window switch and also tested the window motor itself and it works. But it still wont work by using either the drivers side or passenger switches. Any ideas would be appreciated.
Thank you.
Old Apr 19, 2015 | 07:16 PM
Two things you should do first and they are; make sure you have power at the driver's window switch then also make sure you have a good ground at the plug that goes on the switch .The window system is usually fed power through a circuit breaker.
Old Apr 20, 2015 | 12:41 PM
Anybody's Avatar
Thanks. It does have power from master switch to passenger switch. I see the switch light go out when I try lowering window from the drivers side.
Old Apr 20, 2015 | 02:58 PM
There usually is no light visable at the switch unless the dash lights are on also.
Are we talking about the same light?
Old Apr 20, 2015 | 03:12 PM
Anybody's Avatar
Yes I did have the lights on. Yes same lights.
1984/351W
Mar 23, 2017 07:08 PM
hilliad
Sep 8, 2008 12:08 PM
crimey617
Aug 13, 2007 10:38 AM
vinnyqua
Jul 24, 2007 06:28 PM
hilliad
Oct 16, 2006 02:35 PM
