2007 Edge Front Wiper Wash- no go
My 2007 Edge front wipers work, yet no washer fluid will spray. (not clogged), when rear washer is activate, it works fine.
I do not hear the pump hum when front is selected,, silence. I see that front & rear share the same pump. is it the pump? or maybe a wire problem? thx ! |
If you haven't fixed it yet, you could still have a bad pump. The pump runs clockwise and counter-clockwise. The system has one pump that has reversing current controlled by two relays. You could have either a bad pump, a bad relay, or bad connection to/from the relay for the front operation.
