2007 Edge Front Wiper Wash- no go
Old Jan 23, 2014 | 12:01 PM
k2crew's Avatar
Default 2007 Edge Front Wiper Wash- no go
My 2007 Edge front wipers work, yet no washer fluid will spray. (not clogged), when rear washer is activate, it works fine.
I do not hear the pump hum when front is selected,, silence.
I see that front & rear share the same pump. is it the pump? or maybe a wire problem?
thx !
Old Feb 3, 2014 | 08:31 AM
Use Common Sense's Avatar
If you haven't fixed it yet, you could still have a bad pump. The pump runs clockwise and counter-clockwise. The system has one pump that has reversing current controlled by two relays. You could have either a bad pump, a bad relay, or bad connection to/from the relay for the front operation.
badedge
May 14, 2012 03:27 PM
AshleyChereBeaver
Sep 13, 2010 08:00 PM
juangoodude
Nov 27, 2008 09:21 PM
gavin
Dec 8, 2005 05:11 PM
