View Poll Results: 2007 Ford Fusion Automatic Trans.
Stuck on code 757B
0%
Stuck in off position code 760
0%
How to fix these codes
0%
5 speed automatic
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2007 Ford Fusion
Old Jun 16, 2013 | 03:56 AM
Timothy Edmunds's Avatar
Default 2007 Ford Fusion
Can anyone tell me how to fix a Shift solenoid CKT stuck on code 757 B and code 760 performance GR stuck in off positio? Tks.
Old Jun 16, 2013 | 05:50 PM
greasemark's Avatar
These are 2 different problems; the first, if taken (I hope they are supposed to be P0757 and p0760) is a hydraulic concern, the second is circut related.
Let's start with the second first: this means the PCM didn't see the return voltage back on the pin that goes to the specific shift solenoid (If memory serves correctly, its shift sol. c or #3). You could start by checking fuses,obvious wiring concerns, etc.
However, it really doesn't matter as the first code is deadly. It means that when the trans was commanded to shift into a particular gear, it didn't get the ratio it wanted. You might have experienced a slipping, rough, or missing shift. This is indicative that the transmission has something wrong that means it couldn't obtain the gear it wanted when commanded; usually, it means the trans is damaged.
As these are Asian transmissions, they are 5 or 6 speed trannies, and most of these problems become obvious during a rebuild.
Old Jun 17, 2013 | 02:19 PM
Thanks alot I will check this info. out!
cpatt1124
Aug 22, 2010 09:28 AM
HuskerWebhead
Jan 15, 2009 07:59 PM
melco
Jan 12, 2009 02:05 PM
melco
Jan 12, 2009 01:53 PM
melco
