289 oil fill location
Old Oct 9, 2023 | 06:38 PM
Edkon's Avatar
Default 289 oil fill location
I'm helping a friend with a 61 Econoline pick up with a 289 swapped into it. From the numbers found on the engine it appears to be a 289 from a 64 Fairlane. The engine has a spacer plate under the carb with a hose running to where I believe the road draft tube would be attached at the rear of the intake manifold for crankcase ventilation? There are no openings in the valve covers or the timing chain cover to fill oil, is there another fill location? Thanks
09XSCAPE
Oct 10, 2017 02:48 PM
Sanddoc
Jun 9, 2017 04:29 PM
FordGalaxie885
8
Feb 7, 2013 04:37 PM
drybasement
Nov 14, 2011 07:52 PM
elbert
Nov 19, 2005 01:33 AM
