302 with 351 fireing order???
Old Dec 7, 2007 | 12:36 AM
stutzman's Avatar
Default 302 with 351 fireing order???
i have a 302 with suposedly 351W fireing order. is this possible and what dose this mean it has a preformer 289 intake so im sure its a 302
Old Dec 7, 2007 | 01:00 AM
Default RE: 302 with 351 fireing order???
The 302HO has the same order as the 5.8.. Whats the 302 in, or out of?
Old Dec 7, 2007 | 10:42 AM
Use Common Sense's Avatar
I believe the 1-5-4-2-6-3-7-8 firing order was used on all "STOCK" 221/260/289/302 engines from 1962 thru the late 80's. Non-"HO" 5.0's also used this firing order.
The 1-3-7-2-6-5-4-8 firing order was used on all 351 Windsor engines as well as the 82-up "HO" 5.0 engine.
Cylinder numbering [/align][/align]Fire Wall[/align]4 8[/align]3 7[/align]2 6[/align]1 5[/align]Bumper[/align]
Old Dec 12, 2007 | 12:54 AM
stutzman's Avatar
the 302 numbers say it came from a car. block says 70's? i also have a 302 with old 302 fireing order. heads apear same. both blocks have preformer 289 intake and edelbrock 600cfm carb. electronic ign. the only visible differences are trans mount and engine mounts? possibly came from bronco?
Old Dec 12, 2007 | 07:48 AM
Without disassembling the engine and checking the crank, the only other way to verifywhich actualfiring order you have would be to pull all the plugs. Then turn the engine by hand and bring cylinder #1 up to the compression stoke. Then turn the engine and check for a compression stoke on cylinder # 3 or 5. This will tell you which crank is in the engine, thus the firing order.
Old Dec 13, 2007 | 12:10 PM
stutzman's Avatar
so what are the possiblitys? could it just have a 351 cam installed? or would it need different crank?also
Old Dec 14, 2007 | 03:43 AM
What are you actually looking for or trying to figure out? Is the engine in a vehicle? Is it running? Are you looking to rebuild it? It's either one firing order or the other. Intake doesn't matter as far as firing order, so that can be left out for the time being.
Old Dec 14, 2007 | 09:36 AM
stutzman's Avatar
i am trying to figure out how its possible for a 302 to have 351 fireing order. the person i bought the motor from says the bottom has not been touched. and it might have had a cam change. and i really dont think its newer than 82
Old Dec 14, 2007 | 10:58 AM
It's easy for a 302 to have the firing order of a 351. The 302 is a 5.0L engine. All 1982+ HO 5.0 (A.K.A. 302) used the 1-3-7-2-6-5-4-8 firing order. If the engine block is in fact a PRE-1982 Hi-Output 5.0/302, then a crank from a 351 was put into the block during a rebuild or build-up. Is the person you bought the engine from the original owner of the engine?
Old Jan 13, 2008 | 07:11 AM
lawlessone's Avatar
Really curious about what happened and the rest of the story here!
dlingner
Sep 26, 2009 11:58 PM
JTGrant1
Apr 14, 2009 08:42 PM
Hbombmike
Sep 16, 2007 11:04 PM
greasemonkey
Sep 11, 2006 05:10 PM
gt_ute_351
May 1, 2004 11:48 PM
