4x4 doesnt work
I have a 1993 Explorer 4-door. I was stuck in mud a couple days ago... I was in 4x4..... i went to switch to 4 low....... the 4x4 light switch went off and now neither the 4x4 or 4 low work.... i have the dash mounted buttons above the radio to turn on my 4x4. Any ideas? I checked any and all fuses.... I looked in my Explorer book and found out that the shift control module is in the rear left wheel well area.... I dont know what to look for though. Thanks in advance for your help.
Normally What I find is the lil elec. motor on the Transfer Case has hung up , If up look up under there its about the size of a wiper moter ( smaller than a soup can , round ) , there 3 bolts if I remember rite. If the 4 + 4 hasnt been used in awhile they kinda get stuck, Sometimes you can u-bolt them , An have someone work the switch, An they will go to working, , Then bolt it back up , like once every 2 weeks or once a month , just cycle your switches, Sometimes your able to get it to work by playing with in a empty parking lot just drive around slow an activate it, Go foward an Reverse while hitting the buttons, It has a coil set up very similar to an AC clutch .If you cant get it to work by unbolting it , then its probaly bad I have replacrd a bunch of them. But you should make sure your getting power down to it before you replace it with a new one , There pretty pricey !!! ,, Humm thought I answered this one , before ???
[sm=headbang.gif]
[sm=headbang.gif]
93f250xlt4x4
Sep 3, 2006 09:59 PM
