5 spd manual
Old Jan 15, 2009 | 11:15 AM
guido's Avatar
Default 5 spd manual
Will a 5 spd manual transmission from a 1996 Ranger 2 wheel drive replace a 5 spd manual from a 1994 ranger 4 wheel drive?
Old Jan 15, 2009 | 03:52 PM
Bullitt94's Avatar
Default RE: 5 spd manual
What engines are in the two vehicles?
Old Jan 15, 2009 | 04:11 PM
guido's Avatar
Same, 4.0 L 6 cylinder
Old Jan 16, 2009 | 08:38 AM
Bullitt94's Avatar
I think that will work fine.
Old Jan 16, 2009 | 01:12 PM
guido's Avatar
I "thought" it would work also, but I wasn't sure, that's why I asked the question. Is anyone sure it will work?
Old Jan 22, 2009 | 10:08 AM
transguy37's Avatar
Hello,
Don't know if you have done this yet or not, but it will work. But, you will have to tear trans completely down and change the main shaft to fit yours. Good bit of work.
Old Jan 22, 2009 | 03:01 PM
guido's Avatar
Thanks transguy, that would be more work then I want to do. Do you know what years would be compatible to do a simple swap of trannies. And is the shaft change required because of the 2 to 4 wheel drive.
Old Jan 22, 2009 | 04:52 PM
transguy37's Avatar
Yes it's because of 2 and 4 wd. Anything 1990 and up 4.0 will work. Also when you get another trans, before you put it in, there are 3 rubber plugs in the top cover at the back. Take a screw driver and pop them out, dry them off and put some RTV on them and push them back in. Thats where they always leak and run low on fluid and wipe the trans out. As cold as it is right now i would either 10w40 motor oil or regular ATF for fluid. Gear oil is to thick and you wont be able to shift it. Also the trans number is M5R1 if that helps in looking for one.
Old Jan 28, 2009 | 01:02 PM
guido's Avatar
Thanks TG, that is the exact info i am looking for!!!! Much appreciated.
pdamiani
Sep 3, 2009 09:44 AM
lynched1
Dec 8, 2008 06:50 PM
valhallastar
Nov 14, 2007 11:21 PM
blue iron
May 1, 2007 09:59 PM
gonephishin
Jan 3, 2007 11:39 PM
