71' LTD 400 6.6L Troubles =(
Old Aug 5, 2005 | 11:16 PM
IntergalaticMAN's Avatar
Default 71' LTD 400 6.6L Troubles =(
got her for 500 bucks, runs great with 41,784 miles.
i smell a little gas and she sometimes sputters a moment.
when i pull off the airfilter cover i can see two round holes with fuel comming out pouring into the carb. it runs fine but i have to kink the main fuel line in 1/2 to kill some of the fuel to get her to idle.
anyone seen that before,maybe she needs a new carb..
if so i wanted to find a "1 barrel" to replace the 2B-MotorCraft2100, she says its called a Carter YB-1A.
Old Aug 6, 2005 | 11:49 AM
Ramrod48's Avatar
Default RE: 71' LTD 400 6.6L Troubles =(
Dont understand why in the world you would to put a 1-bbl , on it , I dont think it would run, Any way , suggest you re-build the carb. you got . , sounds like the float neddle is hanging open , probaly a lil gum in there. you could try adding several bottles of fuel cleaner to the tank , but I dont think that wil help the immeadite problem , its very easy to re-build these CARB'S
Old Aug 6, 2005 | 06:05 PM
kinkydoints's Avatar
maybe a inline fuel pressure regulator ? might be cheaper
Old Aug 6, 2005 | 09:03 PM
77FordF250's Avatar
I just rebuilt the carb on my truck. Motorcraft 2150 2 Barrel I think. Honestly it was one of the easiest things I’ve ever done and really not a lot of stuff to replace my carb was filthy. And by no means am I a mechanic. HA HA. Well good luck.
petefixer
Jan 20, 2013 08:29 AM
oneslickhotrod
Apr 19, 2008 01:29 PM
texashotrods
Jul 3, 2007 02:56 PM
vigilante4u2
Feb 11, 2007 10:25 AM
cctxfish
Jul 22, 2005 01:32 AM
