77 T-bird 351 V8
Old Jun 20, 2009 | 07:17 PM
sky81's Avatar
Default 77 T-bird 351 V8
Hey all-
I am not a Ford expert, but am trying to help someone with a 77 Thunderbird with a 351 V8 in it.
The fuel line that goes from the fuel pump up to the carb- is it supposed to be steel all the way to the carb, or is there supposed to be a small rubber line right near the carb where the fuel filter is?
I didn't think the small rubber section was right, until I pulled that section off and the end of the steel line had a nub on the end that looks like a rubber section would fit over it. Also the fuel filter, which is attached to the carb itself, also had an end on it which appears to be for a rubber fuel line.
Is this right? I'm surprised they would make it this way at the factory. I would think the rubber section could dry out and crack, causing fuel to leak onto a hot engine and cause a fire.
Maybe other owners with 351 V8s can tell me whether this is how it should be set up.
Thanks!
pgto70
May 13, 2013 11:05 AM
Hbombmike
Sep 16, 2007 11:04 PM
bharrison
Nov 30, 2004 09:55 PM
kjc472
Aug 24, 2004 04:20 AM
gt_ute_351
May 1, 2004 11:48 PM
