89 Ranger: Hazards work, but no turn signals and fuse panael ? .
Old Nov 14, 2006 | 10:22 PM
Luke 22's Avatar
Default 89 Ranger: Hazards work, but no turn signals and fuse panael ? .
New to me 89 Ranger: Hazards work, but no turn signals.
I did replace the flasher relay in the fuse panel All other lights are working. There is no relay clicking with the turn signals.
I don’t have an owners manual. What goes in the empty slots in the fuse panel?
drawing of my fuse panel http://www.geocities.com/bible101a/rangerfuses.jpg
Old Nov 14, 2006 | 10:27 PM
wheelsup68's Avatar
Default RE: 89 Ranger: Hazards work, but no turn signals and fuse panael ? .
The turn signal flasher is separate from fuse block if I remember right. In my 88 ranger it was uderneath knee bolster under steering column. Pull the flasher out you just replaced and see if you no longer have hazard flasher?
Old Nov 14, 2006 | 11:55 PM
Luke 22's Avatar
With the flasher relay removed on the fuse panel the hazards still flash.
Old Nov 15, 2006 | 12:06 AM
wheelsup68's Avatar
sorry bout misadvice, I just though I remembered. could be turn signal switch have u tried wiggle test.
Old Nov 15, 2006 | 12:22 AM
Luke 22's Avatar
Not misadvised I tried it and did not have time to edit post with information.
What is "have u tried wiggle test. "
Old Nov 15, 2006 | 01:38 AM
wheelsup68's Avatar
Just try to wiggle turn signal switch a little bit while trying to operate. jab lever a little to se if it has dirty contacts or something like that?
Old Nov 15, 2006 | 02:57 AM
Luke 22's Avatar
I tried that it did not work.
Old Nov 27, 2006 | 02:43 PM
chevybb36's Avatar
are you sure you have the correct flasher? There are many flashers and some look the same but are different and wont work, if in doubt call dealer or a good part store.
Old Nov 28, 2006 | 02:12 AM
Luke 22's Avatar
On my 89 I am thinking I have an intermittent electrical problem. Thanksgiving morning it would not start to come home from the grocery store. It was getting spark but fuel was not pumping in the line. While the fuel filter was off I was going to replace it on Friday in the parking lot. Friday before replacing the filter the line started pumping fuel. It could be related to my turn indicator lights they are intermittent now they work when they feel like it.
Old Nov 29, 2006 | 12:28 AM
wheelsup68's Avatar
You got yourself a nasty gremlin there. Mabey a bad chassis ground somewhere?
