91' f150 stutters on hwy
Old Nov 30, 2006 | 07:55 AM
farm ford's Avatar
Default 91' f150 stutters on hwy
New to this forum stuff. I have a 91' f150 4x4, 5.0 litter. I have developed a stutter on the hwy exspecially when using the cruise control, going into a slight head wind or slight rise. I have had the plugs, plug wires, fuel filter , cap and rotor, air filter, fuel tanks ,tranny fluid & filter all replaced, plus I have run plenty of injecter cleaner, no change. It almost feels like the choke (if this was carbed )was not opening or it suddenly developed a miss. It has plenty of power if you stomp on it or take it out of overdrive. Could it be some type of air flow sensor or throttle position sensor ? thanks to eney for the help. I need it!
Old Nov 30, 2006 | 12:17 PM
cobra79's Avatar
Default RE: 91' f150 stutters on hwy
It may be converter shudder. If you change the trans fluid get fluid with anti shudder of an aditive that fixs trans shudder. our possible causes plug , plug wire, egr valve. good luck
Old Dec 2, 2006 | 09:04 PM
farm ford's Avatar
thanks for the help . Could it be the MAF sensor? thanks again for the help.
Old Dec 3, 2006 | 05:41 PM
krazytrkr's Avatar
just a thought but i have a 90 f150 with dual tanks had a simaler problem ended up being the paper fuel filter in the canister on the frame rail under the cab.dealer told me it was unservicable.
Bigtodd
Jul 11, 2016 10:13 AM
brown1502003
Sep 17, 2015 01:15 PM
Bigtodd
Dec 15, 2012 10:21 PM
rusty ol ranger
Sep 9, 2005 06:36 PM
