View Poll Results: A poll
yes
0%
no
0%
yes for sure
0%
yes maybe depends
0%
Voters: 0. You may not vote on this poll
95 Lincoln Mark VIII A/C
Old Oct 26, 2008 | 07:58 PM
Davetheslave's Avatar
Default 95 Lincoln Mark VIII A/C
I have oil on my compressor clutch does this mean my compressor is shot?
Old Oct 27, 2008 | 09:14 AM
Default RE: 95 Lincoln Mark VIII A/C
This is located on my A/C system compressor.
Old Oct 28, 2008 | 05:44 AM
Use Common Sense's Avatar
Oil on the compressor clutch doesn't necessarily mean that the compressor is shot. Just means that the shaft seal is worn/breached. Oil leaking out mean moisture can/is leaking in. The moisture in the system can cause acid to form thus causing system deterioration on the inside. Since you have pressure on the high side you know that the compressor is working. However, it would be way cheaper and easier to replace the existing compressor with a new one.
Sunkenkarma
Mar 20, 2015 11:55 PM
Don Pfau
Aug 11, 2011 08:14 AM
agent008
Apr 29, 2010 06:32 AM
HansonHVAC
Jan 4, 2009 01:12 AM
HansonHVAC
Dec 24, 2007 06:01 PM
