95 Sable 3.0L (Fuel & Emission Problem)
Old Nov 16, 2006 | 12:50 PM
dukesport's Avatar
Default 95 Sable 3.0L (Fuel & Emission Problem)
1. What could be causing a heavy amount of fuel to be flowing through the line leading back to the Vapor-Vent on my fuel tank. The amount of fuel & pressure is so great that its blowing the hose off the Emission Vapor-Vent (which doesn't require a clamp)???
2. On the Emission Vapor-Vent itself, there are two nipples for hoses... where does each hose lead to in the engine department; I assume that one of them lead to the carcoal-canister...but what about the other one????
Old Nov 19, 2006 | 07:42 PM
dukesport's Avatar
Default RE: 95 Sable 3.0L (Fuel & Emission Problem)
STUPID ME.....I discovered that the other hose on the fuel tank vapor-vent valve doesn't attach to anything; it just hangs over the side of the fuel tank for venting purposes.
In repairing a damaged portion of the fuel return-line, I had mistakenly connected the fuel return-line to the vapor-vent valve hose that hangs openly over the side of the fuel tank.....THIS WAS THE REASON FOR THE HOSE BEING BLOWED OFF THE VAPOR VENT VALVE WITH FUEL PRESSURE EACH TIME I WOULD START THE CAR.
Old Nov 19, 2006 | 11:50 PM
wheelsup68's Avatar
Glad you found the problem. It did'nt sound very common.
tea
Aug 2, 2006 09:42 PM
jensis7
Jul 31, 2006 12:40 PM
Dutch
Jul 17, 2006 07:48 PM
BCBEEF
Apr 16, 2006 09:37 PM
Edwards
Nov 25, 2005 04:16 AM
