95 thunderbird wont start
HELP!!!
replaced battery and altenator, tested starter, sensor, and relay. someone please tell me what to try next. it wont even turn over!! |
Before I can suggest anything, need some addl info.
When did this engine run last? Does the vehicle have an anti-theft system on it? Can you turn the engine by hand using one of the pulleys and belt? Does the starter click when you turn the key to the start position? |
the car stopped running last Thursday, been trying to fix it since then.
NO, it doesnt have an anti- theft system i didnt hear any noise except fuel pump. the car broke down at a store where it still sits...i will try this today, if i can figure it out. thank you for responding. |
Since you did not hear the starter click I would think the problem lies in the circuit for the starter solenoid. Look up a diagram in the Haynes manual and check every element of the starter circuit. You checked some already, but make sure to include the wires, wire harnesses, and ground connections.
I bet Hanky agrees with that approach. |
If it fixes the problem,,,,,,,,,, of course, I agree ! Has something to do with hindsight being 20/20.
