98 Ford F150 4.6L Window Problem
Im new to the site and have a F150 driver side window (electric) that will not work. When I press the up/down button I can hear a clicking in the #4 relay located in the fuse box. I replaced that but it was not the issue. I took apart up/down switch on door and cleaned contacts and that appears to be working fine. Anyone have a suggesstion what it could be? Thanks
Steve
Steve
Thanks for the advice, did what you said and the window motor was bad. Two labor hours later and 50 dollars for a motor I was in good shape. However had to drill out the pop rivets to get the old motor off, could not reuse them so I used 1/4in bolts and nuts in their place.....worked great.
