99 Escort - rough idle
Old Oct 10, 2010 | 04:05 PM
lady0329's Avatar
Default 99 Escort - rough idle
I have a 99 Escort 2.0 SPI with a rough idle problem. Cylinder pressures are 140, 150, 150, 150, no engine codes, new plug wires & plugs. Have not found any vacuum leaks. The idle is rougher when I have under 1/4 tank of fuel. The fuel pressures are 25psi engine on - 40psi engine off which seems OK. The car cruises at speed nice and smooth. Thoughts from those smarter than I am ??...Thanks
Old Oct 10, 2010 | 04:09 PM
way2old's Avatar
Try replacing the fuel filter first. Your low end fuel pressure is a little low. A restricted filter can cause that.
Old Oct 10, 2010 | 04:14 PM
lady0329's Avatar
Thanks and I forgot to add, we changed the fuel filter.
Old Feb 5, 2012 | 02:49 PM
Sober0782's Avatar
Thumbs down I have the same problem on my 2002 2.0
The engine idles smooth when started and when it warms up it idles really rough, New plugs , plug wires and rebuilt head still idles rough. ?
Old Feb 5, 2012 | 03:02 PM
Rough idle, are you getting a possible misfire? Could one of the valves be a little tight?
Old Feb 6, 2012 | 09:53 AM
Sober0782's Avatar
Smile rough Idle problem
I will have the valves checked its a single over head cam which I thought was Hydrolic valve. I took it to the Mechanic when it was idling rough and he adjusted the air/fuel mixture and it smoothed out but after driving for two days smooth as new it went back to rough idling again.
I have a zx2 , a Ford Escort and a mercury Tracer :-) I really like these cars and find that I can get a long life out of them with normally few Problems. This is the first time I have had this particular problem. thank you for the suggestions Ed
Old Feb 6, 2012 | 06:07 PM
way2old's Avatar
Also there is a possibility the timing belt could be off a tooth. It is easily done and youy can cover the problem up fairly easily. Just a thought cause I did it myself.
Old Feb 6, 2012 | 09:43 PM
greasemark's Avatar
Possibly start by a code scan to look for misfires; even if you don't have a scope (or possibly IDS), you could see if the clyinders are missing. These engines also had a wide array of vacuum hoses with a bunch of bends in them that liked to rot out (this will usually set a code and CEL).
There is another possiblity if everything looks good with the base engine, and you've verified that all the clyinders are contributing more or less evenly. I've owned a dozen Escorts over the years (drive a '99 ZX2 now), and some of these will shake your teeth out of your head at idle, even though the engine if running well. If it is verified that the engine is running well, then replacing ALL the engine and transaxle mounts can/will change a good bit of it.
You may find that you can love your Escort again!
goatsauce
Apr 15, 2013 08:32 PM
93redxlt
Mar 18, 2010 04:44 PM
Olpapa
May 18, 2008 03:22 PM
wheelerlt
Nov 15, 2005 09:40 PM
gearyoil
Nov 1, 2005 07:02 PM
