99 ZX2
Old Dec 2, 2007 | 07:59 AM
allnite1's Avatar
Default 99 ZX2
My kids car,someone replaced the cam sensor,Car runs better with cam sensor unplugged,Is there a prosedure for relearning ecu after replacing cam sensor? Thanks Jeff
Old Dec 5, 2007 | 10:24 AM
oldtimer35's Avatar
Default RE: 99 ZX2
The cam sensor tells the ECU the position of the camshaft relative to the crankshaft, so it can time the injector drop. If it runs better with it disconnected, does it run like it should, or just not as rough? Is the check engine light on and if so, what is the code? It could be that the engine is actually out of time one tooth and that will cause it to have no power. When you disconnect the sensor, the ECU ignores the camshaft sensor for injector drop and goes by crankshaft timing. There is no relearn for camshaft timing. There is probably another problem.
JoeSixPack
May 10, 2018 12:34 PM
farout_one
Jul 9, 2011 09:22 PM
Ritehsedad
May 14, 2005 11:28 AM
badboy zx2
Apr 8, 2005 11:38 PM
FordZX2
Sep 4, 2004 10:30 PM
